Do I need to lift engine out to remove oil pan?
2000 OLDSMOBILE CUTLASS
155,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
RANDY GEBBIE
I removed bolts all around, but the oil pan does not clear the frame.
Oct 24, 2023 at 5:42 PM
STEVE W.
  • 15,113 POSTS
Yes, the engine needs to be lifted up to get clearance for the pan to clear the pick-up and be removed. An easy way is to use an engine support like in the image. You lift it up after loosening the mounts and tilt it a bit. It generally doesn't need to go very far but it won't come out without moving it. Also, you don't want to force it because you could knock the oil pick-up tube out of position.
Oct 25, 2023 at 2:50 AM
