Hi Joe and all of you at 2CarsPro! Thank you very much! It is so gratifying to find guys like you who are generously willing to help with so much expertise and resources. Many times, I find it extremely hard to find info on the web, especially for the not too common vehicles.
I have ordered the s-shaped wrench set which should work but also found some low-profile sockets which should also do the job. Previously in a pinch, I have cut down sockets and welded them to open end wrenches to make a needed special tool.
For the oil pressure sender, I suspect I would just need to remove the right wheel and the splash cover to access?
Thanks a million again for all the help. You guys rock!
Feb 20, 2022 at 1:30 PM
