Oil pan bolts and removal
1999 CHRYSLER CONCORDE
186,500 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
LOWLIFE319
Are the bolts all the same size and are there really two on the front side of motor?
Apr 11, 2021 at 9:41 AM
There are bolts all around the pan but the ones in the corners should be nuts that tighten down on studs that are in the block.
I am attaching the process from the manual that will help answer your questions. Please review this material and let us know if you have other questions. Thanks
Apr 11, 2021 at 7:20 PM
