That's a complicated repair. You are going to need a jack to lift engine and there is special tool needed to hold the engine up while you are removing the pan. Since the truck is 4wd you may need to drop the axle as well. If you are set on doing the repair yourself, purchase a manual it will well worth the investment.
Feb 27, 2016 at 6:47 AM
