Oil pan gasket replace?
2003 FORD F-250
170,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
PUSSY FACE
How do I change the oil pan gasket on my F-250?
Feb 27, 2016 at 5:47 AM
HMAC300
  • 48,601 POSTS
That's a complicated repair. You are going to need a jack to lift engine and there is special tool needed to hold the engine up while you are removing the pan. Since the truck is 4wd you may need to drop the axle as well. If you are set on doing the repair yourself, purchase a manual it will well worth the investment.
Feb 27, 2016 at 6:47 AM
