I am replacing the oil pan seal in the car, and two of the bolts stripped coming out. I was hoping not to put them in, as it is nearly impossible to fix the thread in the engine block. Instead I was wondering if it would work to leave the bolts out (none of the stripped bolts were beside each other) and put gasket maker on the lip of the pan where the bolt is missing. Would this work?
Dec 28, 2018 at 4:56 PM
