If the vehicle overheated then I suspect you have a warped head. I find it odd that someone would say it is not worth fixing on such a new vehicle. Did he mean it would be better to just put an engine in it and not repair the current engine or to not repair it at all and get rid of the vehicle?
If it is making a grinding noise as well I suspect you have a larger engine issue. This is why he may be recommending a new engine which would make the most sense.
Here are some guides that help with this issue:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
https://youtu.be/5zpNjYmmiYY
Please let us know what they found wrong with it but if it is as I suspect that the engine overheated, warped the head, caused the coolant and oil to mix which caused a bearing to fail in the engine, which is making the grinding/knocking noise, then I would agree that this needs an engine and it probably would not be worth repairing this current engine.
Let me know if I am missing something. Thanks
May 15, 2020 at 8:29 AM
