Good afternoon,
You may have a bad oil pump, clogged pick up screen in the pan or worn bearings if the oil is not going to the Top.
You would need to start by doing a manual oil pressure test to see if the pump is working. You can rent a gauge at a parts store. Once you get that reading, let me know so we can continue.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Nov 14, 2019 at 11:20 AM
