Oil light comes on
2004 HYUNDAI ELANTRA
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
ROSALYN CRONE
Also engine sounds rattily.
Oct 29, 2020 at 8:49 AM
We need to start with check the oil level and make sure it is full. If it is not then you need to top it off.
if the oil is full then we need to check the oil pressure. More then likely we have low pressure and if it is making noise as well then the engine may be failing.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
If that is the case, we need to drain the oil and check it for metal. If we find metal then unfortunately the engine will most likely need to be replaced or rebuilt.
Let's start with this and go from there. Thanks
Oct 29, 2020 at 9:49 AM
ROSALYN CRONE
Wow! thanks. will do ASAP. can't believe it was free to get an answer too. Just awesome.
Oct 29, 2020 at 10:29 AM
Haha. We are here to help. Let us know how you make out. Thanks for using 2CarPros.
Oct 29, 2020 at 6:33 PM
