Oil light
2010 FORD FUSION
920,235 MILES • FWD • AUTOMATIC
LISSA8687
  • 5 POSTS
Hi my name is Melissa and my husband and I have a 2010 Ford fusion and the check oil light is on. Here's the kicker, we had the oil changed about a week ago. It comes on when you stop the car. Weird huh?
Feb 28, 2016 at 6:07 AM
HMAC300
  • 48,601 POSTS
check your oil level then check wires leading to oil pan where that sender is and see if any touching anything and bare.
Feb 28, 2016 at 7:50 AM
LISSA8687
  • 5 POSTS
Ok thanks. The light comes on when it's idling and not moving. When it is driven it doesn't come on. Could that be the same thing as you stated earlier
Feb 28, 2016 at 8:01 AM
HMAC300
  • 48,601 POSTS
no this may be the engine wearing out or a bad oil filter and low oil. try a different oil filter like a NAPA, wix or Purolator. but if mileage is at 920,000 i'd say it's probably the engine wearing out
Feb 28, 2016 at 8:42 AM
LISSA8687
  • 5 POSTS
Sorry the mileage is less then 100,000. It's 92000
Feb 28, 2016 at 8:45 AM
HMAC300
  • 48,601 POSTS
ok well it may be bearing wear or an oil filter. try the ones I've suggested then add oil until it's full after you start it.
Feb 28, 2016 at 8:54 AM
LISSA8687
  • 5 POSTS
Ok thanks
Feb 28, 2016 at 2:54 PM
Hi HMAC300 i had an idea on this one, It could be a faulty oil pressure sender as well, please get back to us so it will help others.
Mar 3, 2016 at 9:22 AM
LISSA8687
  • 5 POSTS
Ok I will.
Mar 5, 2016 at 6:50 AM
Looking forward to your reply. Please use 2carpros.com often and tell a friend :-)
Mar 7, 2016 at 5:05 PM
