Oil light
2006 MAZDA TRIBUTE
88,600 MILES • 3.0L • V6 • 2WD • AUTOMATIC
CARRMAN
Oil light flashed on Friday, nothing over the weekend. I checked the oil, full. I looked for leaks and did not see any, though I did not look at the block as I cannot get down on my knees. No noises present. Running within the correct temperature range.
Jun 19, 2017 at 4:55 PM
CARADIODOC
  • 34,306 POSTS
You bounced around everything except the actual cause. The "oil" warning light turns on due to low oil pressure. The light does not turn on in response to low oil level or leaks, although those can lead to low pressure. Given the age and relatively low mileage, a defective pressure sensor is more likely than an expensive engine problem. Oil pressure will drop too if engine speed drops too low. If you only saw the light when something caused the engine speed to drop, the light turning on can be expected, and that does not point to an engine oil system problem.
Jun 19, 2017 at 9:26 PM
