Welcome to 2CarPros.
Because of the mileage, I recommend that you check oil pressure with a mechanical oil pressure gauge. Most parts stores will lend or rent the gauge to you. All you do is remove the electric oil sending unit and screw the mechanical one in its place. Once you start the engine, you will see how much pressure you have at idle.
Now, if you are not hearing any ticking or knocking when the light is on, that is a good thing. However, we need to confirm it isn't truly a pressure issue.
Here are the manufacturer's specs for minimum pressure requirements before the light turns on and at 2500 rpm's
2006 Dodge or Ram Truck Durango 4WD V8-4.7L VIN N
Pressure, Vacuum and Temperature
Vehicle Engine, Cooling and Exhaust Engine Engine Lubrication Engine Oil Pressure Specifications Pressure, Vacuum and Temperature
PRESSURE, VACUUM AND TEMPERATURE
Curb Idle .................... 25 kPa (4 psi) minimum
3000 rpm .................... 170 - 550 kPa (25 - 80 psi)
________________
One last thing, make sure the sensor you replaced is the one next to the oil filter and there are no leaks. Also, make sure the oil is clean and full and you have a good quality oil filter installed.
Let me know what you find.
Sep 13, 2019 at 8:51 PM
