Causing a regular misfire, white smoke for a few minutes as it burns the oil out. While looking it over I did notice the electrical connector to the injector is a little loose, which may be causing the misfire, but I don't think it would cause the oil to leak into the cylinder. wet compression test confirmed good oil rings. Possibly valve stem seals? Questionable but not sure.
Nov 17, 2020 at 1:27 PM
