For some time now, I have been seeing oil on top of the valve cover of my vehicle listed above, on where the coil/plug wire is clamped to the plugs on-top of the cylinder head, and the oil use to enter into the spark plug chamber from the top and settles on top of the plug cap area, not in the combustion chamber, hence, when I want to remove the spark plugs, oil will settle on the plugs, while the sparking area will be dry at-times with carbon deposits on it. The oil leaks out from the cylinder head and I have changed the valve cover oil seal.
Sep 28, 2020 at 11:04 AM
