I noticed a sudden onset of engine power and apparent misfiring. went to check the spark plugs and oil was in all four cylinders. Appears to be some oil around the cover but not too much. It happened very suddenly (engine sputtered and idle became rough), after all that I noticed a large loss in acceleration power.
What do you think is the more likely issue? Valve cover gasket, piston ring or something else? Need to mentally prepare for the repair cost if it's a piston ring.
Mar 27, 2019 at 6:51 AM
