Oil leak
1999 FORD TAURUS
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
BETTY MCDOUGLE
  • 6 POSTS
I have an oil leak. Seems to be coming out the front of the engine. Leaking and smoking because it is leaking on metal. Can see leaking on ground. oil leak.
Jun 6, 2017 at 9:39 PM
This could be the front main seal leaking or a oil pressure sender, here are two guides that will help, you get the problem fixed.
https://www.2carpros.com/articles/front-main-seal-replacement
and
https://www.2carpros.com/articles/engine-is-leaking-oil
Jun 9, 2017 at 4:46 PM
BETTY MCDOUGLE
  • 6 POSTS
The leak on my 1999 Taurus is to the left on the bottom top of motor.Right under a the last bolt to the left. I can see it coming out when car is on .Its like pressure making it come out.. Do not see a leak when car is off.
Jun 15, 2017 at 1:53 PM
This sounds like it could be the oil pressure sensor. Here is a diagram (below) of its location so you can check it out.
The sensor will leak and run down to the bottom of the engine, use a flashlight to confirm.
You may need to raise the car
Jun 15, 2017 at 3:05 PM
DEXTER THOMPSON
Thank you!
Jun 17, 2017 at 3:38 PM
You are welcome :) Please let me know what happens
Jun 17, 2017 at 10:35 PM
BETTY MCDOUGLE
  • 6 POSTS
After putting the gasket on. The oil leak is ok,but now my fans won't. Come on making the car run hot. Fans were good until then Now a friend. Says its thermostat and freeze plugs. Will this solve the problem? Another friend who works on cars say its needs a fan motor. HELP. Thanks.
Jul 11, 2017 at 3:53 PM
Please start a new question
Jul 11, 2017 at 7:30 PM
