Serious oil leak
2007 FORD FUSION
125,621 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
TETESLAYYY
I repaired rear main seal, head gasket cover, seal the oil pan new oil and transmission fluid, but I had to replace speed sensor and I have two so I thought I should have both fixed. so I'm waiting on input speed sensor for transmission to come. I was wondering would that help the leak?
Dec 6, 2020 at 2:53 AM
This is hard to know based on this information. Where is the leak coming from now? When you repaired all these seals were they leaking or has this happened since you repaired them?
Also, can you get a couple pictures of where this is coming from so we can find out possible causes? Lastly what type of oil is it that is leaking, transmission or engine oil?
Here is a guide that will help with more general items:
https://www.2carpros.com/articles/engine-is-leaking-oil
Thanks
Dec 6, 2020 at 7:52 AM
TETESLAYYY
It is engine oil and I have some videos I can show, but the oil is coming up like it's built up pressure in the engine and it's trying to escape but it cannot escape and there is white smoke coming out the tailpipe. so I'm guessing it's burning the oil but I do not know why.
Dec 6, 2020 at 7:56 AM
So I think we are confusing issues because white smoke would mean coolant is getting burned through the engine and not oil. Oil would be more blue.
Here is a guide about the smoke that will explain it in more detail:
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
As for the oil, you said in the video that you checked the oil and it was not like that and now it is? How did you check the oil? Can you get a picture of the dipstick that you used and did you add any oil? If so, just make sure the cap is back on the engine and tight.
Also, if you can give more detail about when this started. If it wasn't like this, can you tell me where the most amount of oil is and what color it is? Get a picture of this oil on a piece of paper if you need too. Thanks
Dec 7, 2020 at 3:04 PM
TETESLAYYY
What is best rebuild my engine or use one?
Dec 8, 2020 at 6:38 AM
I am not sure you need to rebuild it but if you are going to do the work, I would always rebuild it. If you are going to pay someone, then I would get a used engine with a warranty on it just in case it has an issue.
Dec 8, 2020 at 5:32 PM
