Oil leak due to crankshaft end play
2002 GMC ENVOY
295,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
DALE1079
I have an oil leak due to crankshaft end play. It is too expensive to fix and is out about an eighth. Would an oil leak sealant help with the leak? The amount leaked out seems like a lot but the dipstick level really does not move which I find confusing. Any help would be appreciated.
Sep 28, 2016 at 10:57 PM
CARADIODOC
  • 34,306 POSTS
Crankshaft end play is controlled by the thrust bearing which is part of one of the crankshaft bearings. If there are no other problems, it is acceptable to replace that bearing, but you will usually have to buy the complete set. Chemical additives keep rubber seals pliable so they will bend to seal to items that are moving away from their lip a little. That could apply to a worn front crankshaft bearing that is allowing the snout of the crank to move up and down a little. Additives do not work when the sealing surface moves away from the lip seal. That is what happens when the crankshaft walks back and forth. The movement has to be rather significant to cause a leak at the front main seal. Typically 1/8" of end play wont be enough to pull the snout back far enough that the lip of the seal runs off the machined surface. Excessive end play is more likely to push the front seal out of its housing, and that is when the leakage occurs. If your seal is still in place, I would suspect it just needs to be replaced.
Sep 28, 2016 at 11:45 PM
