Hello again,
Yes, you can. A good sealant to use on valve covers is black RTV. Just lay a nice even bead all the way around the valve cover, being mindful of the bolt holes, and tighten down the bolts the hold the valve cover to the top of the cylinder head. Start from the middle and work your way out alternating from side to side. Do not over tighten. Just get the bolts snug and then tighten another 1/4 turn and you should be good.
Thanks,
Alex
2CarPros
Aug 20, 2019 at 8:38 AM
