Oil leak
1996 ACURA TL
165,000 MILES • 2.5L • 5 CYL • FWD • AUTOMATIC
TOM KEATING
Oil leak near back of valve cover, or distributor onto the exhaust system causing smoke and smell from engine.
Aug 1, 2017 at 11:52 AM
What happens on these engines is the oil return galleys get plugged up and then fill with oil which in turn leaks. Here is a guide of what it takes to remove the valve cover to confirm the problem:
https://www.2carpros.com/articles/replace-valve-cover-gasket
Aug 2, 2017 at 4:37 PM
