Oil leak
2007 GMC SIERRA
129,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
CODY07GMC
  • 6 POSTS
I just bought this vehicle from a Chevrolet dealer and drove it about two weeks and it said low oil when I was pulling a s10 Chevrolet truck about ten miles. So I added oil drove for about another week or so and said low oil again. So I parked it in the garage and noticed oil spots on the ground. What could cause this and what would it cost to fix? Also, I had a friend tell me he saw blue smoke when I started it up. I have not had a chance to see the blue smoke.
Dec 1, 2018 at 3:25 PM
Good evening,
Do you have any idea where the oil leak is located or the area? There are so many places oil can leak.
https://www.2carpros.com/articles/engine-is-leaking-oil
What would really help us id if you could take some pictures and upload them to this post so we can see it and further help you.
Dec 1, 2018 at 6:35 PM
CODY07GMC
  • 6 POSTS
I looked under the truck is seems to be coming somewhere around the oil filter.
Dec 1, 2018 at 6:41 PM
Check the oil filter and see if it is tight and that it does not have a double gasket. Common issue.
Dec 1, 2018 at 6:51 PM
CODY07GMC
  • 6 POSTS
What is a double gasket?
Dec 1, 2018 at 6:52 PM
CODY07GMC
  • 6 POSTS
I also do not see it actually leaking just oily around the housing unit.
Dec 1, 2018 at 6:55 PM
When they change the oil there are times the old gasket from the oil filter sticks to the housing and when the new one is installed, it doubles and leaks.
The oil pan is around there as well.
Can you post some pictures?
Dec 1, 2018 at 6:57 PM
CODY07GMC
  • 6 POSTS
This is all after I gave it a little wipe down.
Dec 1, 2018 at 7:05 PM
That is your leak at the oil filter.
Spray that down with a can of brake kleen. Then run the engine and watch for the leak so you can pin point it.
Dec 1, 2018 at 7:10 PM
CODY07GMC
  • 6 POSTS
So you think it could be because it has a double gasket?
Dec 1, 2018 at 7:12 PM
That is correct but you must inspect to be sure.
Dec 2, 2018 at 4:53 AM
