I have been having a small oil leak for a couple of months now. at first I replaced the transmission fluid pan gasket, the problem went away for a few weeks, then it came back. It is only a small, slow drip and it is only in one spot. After taking it to my mechanic to get the engine oil pan gasket replaced, he told me that was not the issue, the valve cover gasket was the culprit. Well, I just replaced that valve cover gasket yesterday, along with the grommets, and now it seems like it is leaking in several different areas. I used a FelPro gasket, with engine sealant, all screws were turned tightly so I do not know what the problem is. I took a video under my car and a lot down there just seems to be greasy. any ideas?
Mar 29, 2018 at 10:53 AM
