Oil leak from the area near the oil filter
1988 DODGE RAM
120,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
PJROXX
  • 4 POSTS
While driving or at a stop or after shutting off there is a leak that is a very thick stream coming down from the area near the oil filter? Need some good advice. Thanks
Jul 30, 2019 at 9:59 AM
Welcome to 2CarPros.
Are you certain it isn't the filter? Also, most times the oil pressure switch is near the filter. Check that also. However, if this is a 3.9L the switch is on the rear top of the engine. Have you checked valve covers to see if they are leaking?
Jul 30, 2019 at 10:15 AM
Good afternoon,
It sounds like it is leaking under pressure. The one spot that it could be is the oil pressure switch.
Jul 30, 2019 at 10:16 AM
PJROXX
  • 4 POSTS
Hey Joe, thanks for you quick response. I checked the filter it was rather tight, it is the 3.9 so I do not know if the oil switch is still a possibility, my oil pressure always runs on near last tic mark. The valve cover gaskets could probably be changed, I just didn't think it would leak like a sieve from that?
Jul 30, 2019 at 10:19 AM
PJROXX
  • 4 POSTS
Hey Roy, was that diagram regarding the oil pressure switch for a 1988 Dodge Ram 3.9?
Jul 30, 2019 at 10:31 AM
That is correct. Very common area for the leak.
roy
Jul 30, 2019 at 10:38 AM
PJROXX
  • 4 POSTS
Okay, thanks, I will replace it.
Jul 30, 2019 at 10:40 AM
You are welcome.
We are always glad to help.
Jul 30, 2019 at 10:41 AM
