Sounds like the engine bearings are damaged. If the oil level is low, that is the cause of the problem. If the level is okay, it is hard to say which came first. Worn bearings will cause low oil pressure, and that usually gets gradually worse over many miles. Low oil pressure will cause worn bearings, and once that starts to take place, the wear accelerates very quickly. The bearing wear causes the loud knocking in the engine.
Regardless of which came first, low oil pressure results in insufficient oil being sprayed onto the cylinder walls to lubricate the pistons. That results in loss of power and usually overheating. If the engine is stopped right away, many of its internal parts can often be saved. When people try to force it to keep running, more and more parts become damaged from lack of oil, then a total rebuild becomes more expensive, and a used engine from a salvage yard becomes a better deal.
Jan 4, 2017 at 3:52 PM
