Uses a lot of oil which seems to go straight into the water system.
Head pressure test is 125PSI all four cylinders with cold engine.
Radiator pressure test holds 15PSI with very little drop over 30 minutes.
Timing case and water pump gaskets renewed but no damage found on old ones.
There is a lot of water in the oil sump now.
When it runs there are no misfires, and the plugs all look the same.
I’m at a loss where this oil/water ingress is.
Thanks,
Stewart Lawson
Thanks,
Stewart Lawson
Mar 23, 2022 at 11:09 AM
