My check engine came on about a day ago. Checked the code came out p0356. Ignition coil on number six has faulty primary/secondary circuit. Went to remove it and came across oil in the plug chamber. Not a lot maybe less then one teaspoon. Other two were dry. Have not done anything else so far besides inspect. Any opinions on what direction to take next? Valve cover gasket has never been changed. Hoping it is not worn valve guides or piston rings.
Feb 3, 2018 at 10:55 AM
