Milky oil stuff is in my radiator reservoir. what can it be?
Feb 7, 2017 at 11:54 AM
SATURNTECH9
CERTIFIED EXPERT
Are you sure you do not have the V6 engine? because those engines are known for that happening.
Feb 7, 2017 at 1:24 PM
SATURNTECH9
CERTIFIED EXPERT
You put you have a 2.0L engine which those cars only came with a 2.2 four cylinder engine or a 3.0 v6 engine. I have to know before I give you the most likely cause.
Feb 7, 2017 at 1:25 PM
THALL72
MEMBER
You are so right 3.0 v6
Feb 8, 2017 at 9:34 AM
SATURNTECH9
CERTIFIED EXPERT
If you have oil in the coolant most likely you have your oil cooler leaking and doing that.You would have to remove it to know for sure and test it with compressed air submersed in water.But more them likely its the oil cooler.Common issue on those.
