Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Charger
Engine Cooling
Radiator
oil in radiator
2007 DODGE CHARGER
190,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
RAYDLT23
MEMBER
1 POST
FOLLOW
I did the engine block test to see if it might be a blown head gasket and the test came in negative. what can it be? maybe the oil cooler?
Apr 8, 2020 at 2:14 PM
CERTIFIED EXPERT
Yes. You are probably correct that the cooler is the issue.
Here is a guide that talks about this issue in general terms but I attached the process on how to replace it:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Let me know if you have questions. Thanks
Apr 8, 2020 at 3:20 PM
