oil in coolant
2000 DODGE NEON
140,000 MILES • 2.0L • 4 CYL • 2WD
MARCI PAWN
recently replaced head and all gaskets. Timing belt had broken.
May 24, 2020 at 7:33 PM
Just so I am clear, you had this work done and now the coolant and oil are mixing? If so, I would suspect the head was not torqued properly or something else was done wrong to cause this. Here is a guide that covers this but again with this history, I would jump to the head gasket again:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Let's test for hydrocarbon in the coolant and go from there. Here is a guide on how to do that:
Let me know what you find and we can go from there. Thanks
May 24, 2020 at 8:00 PM
