About three months ago, my air compressor on my car went bad. So now I am getting my air compressor installed tomorrow. I went on a vacation about a month ago. But before I left I noticed that the antifreeze coolant was leaking. I went to the mechanic and got it checked. My mechanic only change the thermostat and the leaking stopped for a little while. But then a few days passed and it started leaking again, and I open up the top to pour in the antifreeze solution. I opened up the top from where the antifreeze coolant is connected to the radiator and I noticed that there was a grayish goo on it and cleaned it up. I am not sure if it is the motor oil. I have checked online to see what the problem might be but I am not sure if it is the head gasket that has gone bad or if it is the transmission air coolant that needs to be replaced.
Aug 2, 2017 at 10:01 AM
