This could be due to a faulty oil pressure sensor.
Are you experiencing any drivability issues?
The other possibility is having incorrect oil pressure.
To figure out if it is a bad sensor or actual oil pressure issue, you will have to test the oil pressure using a pressure gauge. Those gauges can be found at your local auto parts store. Most of them will let you borrow them to use.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
I have attached diagrams for the testing procedure below for your reference.
Thank you.
Mar 19, 2022 at 10:09 PM
