Oil gauge
1995 CHEVROLET CAPRICE
194,000 MILES • 0.8L • V8 • 2WD
MG STEEL
  • 18 POSTS
When car off where should oil gauge rest or do suppose be down or up. if up what can cause it to stay up?
Dec 12, 2019 at 7:27 PM
STEVE W.
  • 15,113 POSTS
The motor used in the gauge will normally stay wherever it is when power is cut as you turn the key off. Once the car has sat a few seconds it will usually return to zero if you were to turn the key back on but not start the engine.
Dec 12, 2019 at 10:08 PM
