Good morning,
Never, ever use stop leak. First, it never works and second, it will damage all the other seals with the additives it has in the product.
https://www.2carpros.com/articles/engine-is-leaking-oil
The front cover will have to be removed and the seal replaced.
No, the engine does not have to be removed. It is a major job but does not require the engine to be removed.
Yes, it will be okay as long as you keep oil in it but the leaking oil will get on the hot engine components and give you smoke and smells.
Chain Cover
REMOVAL
NOTE:
When replacing a single part, perform the work with the engine assembly installed to body.
1) When working on the vehicle
NOTE:
When working on the vehicle, perform the following steps also.
(1) Remove the radiator.
(2) Remove the front exhaust pipe.
(3) Remove the bolts which secure the generator cord stay to the chain cover.
(4) Remove the power steering pump.
1. Remove the V-belts.
2. Remove the generator.
3. Disconnect the connector from power steering pump switch.
4. Remove the power steering pump from the engine.
5. Place the power steering pump on the right side wheel apron.
2) Drain the engine oil.
3) Remove the water pump pulley.
4) Remove the crank pulley.
5) Remove the engine harness stay from the chain cover.
6) Disconnect the connector (A) from the oil control solenoid RH, and the connector (B) from the camshaft position sensor RH, and remove the clip (C) and clip (D) which secure the engine harness.
7) Remove the rubber cap from the oil pressure switch.
8) Disconnect the terminal (A) from the oil pressure switch, and connector (B) from the engine oil temperature sensor, and connector (C) from the oil control solenoid LH, and connector (D) from the camshaft position sensor LH, and remove the clip (E) and clip (F) which secure the engine harness.
9) Pull out the oil level gauge (A), and remove the oil level gauge guide (B) and idler pulley (C).
10) Remove the chain cover.
11) Remove the O-rings from cylinder head RH, cylinder head LH, cylinder block LH and oil pan upper.
Jul 1, 2020 at 4:54 AM
