My car ran hot the other night. I cut it off it didn't shut itself off. I put water in it then limped it home. It tried to run hot again i shut it off before it got close to max heat. I tired to turn the heater on but no heat would come out if that helps at all. I got it towed home. It starts, runs rough as hell but starts. I went out to day to see if i blew the head gasket cause it was bellowing white smoke that night when i limped it home although it would stop smoking out the back for a min while i limped it. I noticed it wasn't really milky definitely discolored like water mix but not that badly what concerns me most is that my oil smells like gas and it drips like water. Something got in the oil because the oil level is way too high. i just got the oil changed 500 miles ago.
Jun 10, 2019 at 4:37 PM
