I was hearing slight tapping from lifters so I changed the oil and filter and a jelly bean size peace of quick steel fell into oil filter housing was not able to fish it out. so I finished oil change started the car and now no oil is going to the top of motor lifters are bone dry. I took valve coves off and expansion cover saw nothing. And no oil came out of expansion port hole. was that bean big enough to stop flow or has my pump gone out? Also oil does come into the filter housing but if the filter stick is in, the oil spills over when cap when it is removed, but if I leave oil stick out oil does not spill over. also oil filter stick is broken away from cap but the stick it self is fine. what is my best option for a remedy where did that bean flow to so I can remove it if possible?
Apr 10, 2019 at 8:48 AM
