oil everywhere
2002 DODGE STRATUS
180,000 MILES • 2.4L • 6 CYL • 2WD • AUTOMATIC
BIGAL831
  • 9 POSTS
i got this used car and it ran fine but wont start now and there oil all over the front valve cover didnt see any leaks around the heads just the valve cover and i check the oil and there no change in color in it so you think you can help out ... thank you
Apr 8, 2016 at 4:40 PM
HMAC300
  • 48,601 POSTS
check to see if pcv valve is working may not be and blowing oil out cover. you'll need to replace valve cover gasket
Apr 9, 2016 at 6:47 AM
BIGAL831
  • 9 POSTS
ok i change it and it did it again should i take the whole cover off and clean it to
Apr 16, 2016 at 11:04 AM
HMAC300
  • 48,601 POSTS
it may be blowby but yes change the valve cover as well. If it continues to leak oil after replacing the gasket check compression
Apr 16, 2016 at 12:25 PM
