Oil drippim off air con pump
1998 TOYOTA STARLET
190,000 MILES • 1.3L • 4 CYL • FWD • MANUAL
FANTA
I have oil drippin off the air con pump on my glanza starlet. We have changed a cam seal and chafed the sump seal. After the the sump seal was changed the car was left to run for two hours and no leaks but once i drove it home and looked under the car in the mornin there was a fresh oil puddle. The oil only drips off the air con pump . Any ideas wat could be wronf and where it is comin from? Sump is completely dry checked seal on oil filter as well all good
Sep 30, 2015 at 1:26 PM
MHPAUTOS
  • 31,937 POSTS
Make sure that the oil seal that you replaced is not leaking, you may have to remove the timing cover and was down and re check for fresh leaks again.
Oct 1, 2015 at 3:17 PM
