oil dipstick tube rusted and broke
2002 FORD WINDSTAR
200,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
CAMERON STAATS
the oil dip stick rusted away at motor how do i get the tube out
Feb 20, 2015 at 1:00 PM
CARADIODOC
  • 34,308 POSTS
If that is just slid into a hole and it's broken off flush, the proper way is to remove the oil pan and push the broken part up and out. What I would try first is to run in a bolt and hope the threads cut in and grab it hard enough that you can pull the tube out by the bolt head. If you have the time, wash the tube out with a little cleaner on a cotton swab, mix up some epoxy, then use that to glue in a long bolt or metal rod. Ideally you want something with a head on it so you can tap on it to pop the tube out.
Feb 20, 2015 at 1:12 PM
