oil dipstick tube replacement?
2003 CHRYSLER PT CRUISER
60,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JERRYSIDDOCK
  • 58 POSTS
i noticed some oil in a puddle and found the oil dipstick tube broken where it enters the oil pan. lacking a hoist, is there a procedure i should follow?
does the radiator come out to facilitate this?
the guy that changed radiators didn't secure the dipstick and
I'm not sure what size bolt ties the tube to a spot on the underside of the intake manifold.
Apr 21, 2025 at 7:55 AM
It helps to have a lift, but it is not mandatory, here is a guide to help you raise the car up safely:
Usually, the bolt size will be a 10mm. If it would make the job easier, I would remove the radiator. Please upload an image of the problem so I can help. Check out the images (below). Let us know how it goes.
Apr 22, 2025 at 11:22 AM
JERRYSIDDOCK
  • 58 POSTS
turns out having a lift did make it easier. a guy was able to get the oil dipstick tube stub out of the oil pan without removing the radiator. i never could have done it myself laying on my back working one handed. Thank you, Ken, for the suggestion.
Apr 30, 2025 at 4:51 AM
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Apr 30, 2025 at 10:45 AM
