oil consumption
2002 BMW 325I
200,000 MILES • 2.7L • 6 CYL • FWD • AUTOMATIC
HAZEEN
hi, i replaced the CCV in my car, but i am still experiencing oil consumption. there is
no white or blue smoke coming out form the exhaust and no over heating. the
engine work in good health no leaks. i want to know what is the problem? some
one told me that I should replace the valve cover gasket, but no smoke from
exhaust to consider that the problem from valve cover gasket. help please!
Oct 14, 2016 at 1:27 AM
JIS001
  • 3,412 POSTS
Check your PCV system. Remove the oil cap and place a piece of paper over the oil fill hole with engine running. There should be a slight vacuum. If no vacuum then replace the oil separator box (PCV box).
Oct 14, 2016 at 10:03 AM
