Oil change
2005 RENAULT CLIO
199,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
BBONDOV
  • 10 POSTS
I was change my oil but I put a new one through the dipstick hole.Is it a problem or no?
Apr 6, 2020 at 11:17 AM
Just to clarify, you put the new oil through the dipstick hole? If this the case, that is not an issue but I am sure it took a while to get all the oil into the engine. The dipstick hole leads to the oil pan and the oil fill goes into the top of the engine and the oil drains down through the engine until it gets to the pan. Either way, the oil drains back to the pan so it is okay. Just make sure the bottom of the dipstick tube didn't leak. If you have oil on the ground, you will want to make sure your engine is full by using the dipstick to check it.
Let me know if you have questions. Thanks.
Apr 6, 2020 at 11:37 AM
BBONDOV
  • 10 POSTS
Thank you very very much for this answer KASEKENNY1.
I will drive back to home after work and will write here if have something change..
But yes your answer really helped me!
Apr 6, 2020 at 11:47 AM
Great! Thanks for the update. Let me know if you need more info on this one. Come back to 2CarPros in the future if you have other questions. Thanks
Apr 6, 2020 at 2:24 PM
