Honestly, I can't think of anything that would cause both to go at the same time other than a coincidence. What you can do to help identify the PS leak is purchase a dye to put in it. Clean old oil and dirt from the pump, hoses, and steering gear. After that, put the dye in it and run the truck. After that, using a black light, you will be able to see where the leak is coming from. You should be able to get the dye at most parts stores.
Let me know what you find.
Jul 6, 2020 at 1:47 PM
(Merged)
