OHC valve diagram and description of head rail
1993 NISSAN PATHFINDER
100,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
ROBERT ERWIN
  • 18 POSTS
I am not sure how the oh valve system works. Are there four valves per cylinder operated by two separate cam shafts? Have suspected bent valves do to bad timing belt. Please answer.
Oct 26, 2018 at 1:36 PM
Good afternoon.
If you feel you have bent valves from a failed timing belt, I would perform a compression test to verify.
Remove all the spark plugs and check the compression in each cylinder. They should be around 130-140.
Oct 26, 2018 at 2:10 PM
ROBERT ERWIN
  • 18 POSTS
can you sent me a diagram of the valve system on a 3.0 1993 pathfinder
Oct 28, 2018 at 7:28 PM
I attached some pictures for you.
Oct 28, 2018 at 7:46 PM
