Offset between shock and mag - major problems
2007 ALL OTHER MAKES ALL OTHER MODELS
115,000 MILES • 1.4L • 2WD • MANUAL
BRONHOOGH
The offset between my 15 inch mag and shock on a TATA indica bounce 2007 model is incorrect - even after replacing the rear axle bushes the shock was still touching the tyre on the side (rear drivers side - passenger side no problems) when there was weight in the car. We added spaces (not that thick about 6mm) so that the shock does not touch the tyre but now in a matter of 4 months I have replaced the wheel bearings about 5 times - I have to go and replace them again now. The wheel bearing seems to get damaged easier once I wash my car - strange enough
Aug 25, 2014 at 4:20 AM
HMAC300
  • 48,601 POSTS
don't know what type of car this is but if you are losing wheel bearing s after washing car you are probably getting water into it past the seal and all the lube is gone plus using a larger tire that is spaced more putting more pressure on it.
Aug 25, 2014 at 7:03 AM
