Odometer not working
2013 NISSAN ALTIMA
145,000 MILES
GASTONE3000
my dashboard light not on, odometer not working, radio light on but not playing.
Dec 18, 2018 at 5:27 PM
We need to check fuses # 29, 25 and 15. If they are okay we need to check the accessory relay. Here are the radio wiring diagrams so you can see how the system works. Also the fuse location and the relay as well. These guides will help you test the fuses and relay. Both can affect the odometer which is controlled by the BCM.
and
If everything checks out I would think the BCM is out which will need to be programmed for $130.00 at a shop.
Check out the diagrams (below). Please let us know what happens. Cheers, Ken
Dec 20, 2018 at 6:00 PM
GASTONE3000
Thanks for reply. We've checked all fuses are okay.the radio is playing okay. the main issues is odometer not spinning, dashboard light off.
Dec 21, 2018 at 8:09 AM
Okay, that leaves the BCM going out but to be sure we need to scan the CAN. Here is a video to help confirm the issue:
https://youtu.be/InIlnsjOVFA
Dec 22, 2018 at 12:16 PM
