The most common failure item is the vehicle speed sensor, but to start diagnosing this properly you will need to retrieve codes from the power-train control module and the instrument cluster module, then go from there.
Image (Click to enlarge)
Feb 11, 2020 at 7:40 AM
CERTIFIED EXPERT
Here is how you get he codes to confirm the failure. The output speed sensor is "A" on the diagrams.
