Odd brake pedal problem
2000 JEEP WRANGLER
250,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
HATTONR
My vehicle has a 2000 Wrangler brake system (due to 35" tires, needed for improved braking). It was all working fine and then I attempted to use the Winch to rip out a bush. Holding the brake and powering the winch, the cable finally snapped (3/8 steel cable!) and it blew out a brake line. I repaired the leaking brake line and properly bled the brakes and everything seemed fine. Now, when stopping, the brake pedal works fine the first time you press it, but if you let off and press it again it goes down further. let off again and it goes down further. until it is at the floor. If you just press it once it is fine. Once stopped, then you drive again, the same situation. The only thing I can think is the seal in the master is doing strange things and the master cylinder should be replaced, but I do not want to just start swapping parts unnecessarily. I have grown used to the issue, but it is unsafe and my wife has driven the truck and is not happy. :-)
Sep 1, 2017 at 3:48 AM
CJ MEDEVAC
  • 11,004 POSTS
I would suspect there is air in the lines. These guides can help you fix it.
https://youtu.be/w7gUsj2us0U
and
https://youtu.be/WDxvEQrMkBg
and
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Mar 15, 2021 at 1:30 PM
HATTONR
That was my "guess"... especially since the MC came from a scrap yard...
I ordered, replaced and bled the MC - finishing up with a full vacuum bleed of the system and now everything is back to "normal".
Of course, with the big tires, normal is still not necessarily great. Still waiting for some "me time" to modify a Ford 8.8 axle with disk brakes and replace the little Dana with drums that comes stock on these Jeeps - but that'll be a whole new set of questions.
THANKS!!
CJ MEDEVAC
  • 11,004 POSTS
Glad you are good to go now!
