My scanner tool powers up but when I turn on the key it fails to communicate and gets an error.
I checked the following:
1. ODB fuse is good.
2. I get power on pin 16 of ODB port.
3. I made the female pins smaller on the ODB port to confirm the pins weren't too loose to make a connection.
4. I had an extra ECU that I put in for a quick test and still see the same issue.
5. Voltage I measure on the pins when I turn the key on. gnd to pin 7 - 8.3V, gnd to pin 13 - 11.04V, gnd to pin 14 - 11.35V.
6. started to unplug sensors one at a time but can't find them all.
Jul 16, 2025 at 9:46 AM
