Truck started shifting funny no forward movement Od off light flashing and transmission fault light on
2005 FORD F-150
240,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
JIMMY MEADE
  • 7 POSTS
Truck started shifting funny then get no forward movement without it revving high. Codes p0720 and p2160 also a p2198. changed OSS wiring looks good except for two pinches at connector cleared all codes, but problem is still there.
Sep 20, 2016 at 7:13 AM
Yes it will give the OSS code when the input shaft and out put shaft do not match when the transmission is slipping, it might be time for a rebuild.
Please let us know what you find so it will help others.
Best, Ken
Sep 24, 2016 at 4:37 PM
JIMMY MEADE
  • 7 POSTS
So the input sensor could be faulty
Sep 25, 2016 at 2:40 PM
Yes is could, I would, sorry I though you changed that already. Try that first
Sep 25, 2016 at 3:18 PM
JIMMY MEADE
  • 7 POSTS
Only changed ouput sensor
Sep 26, 2016 at 5:42 AM
You changed it and it helped or?
Sep 26, 2016 at 9:39 AM
JIMMY MEADE
  • 7 POSTS
Nothing happen still the same reverse loads up no problem
Sep 26, 2016 at 12:52 PM
It sounds like the transmission has gone out, Please let us know what happens.
Sep 26, 2016 at 2:50 PM
