Occasionally stalls
1989 CHEVROLET 3500
115,000 MILES • V8 • 2WD • AUTOMATIC
RONBELIFORE@YAHOO
  • 4 POSTS
The truck starts fine idles high. When I give it gas it may stall and shake resulting in no power steering or brakes, if I drive down the road it will clear up. It also uses a lot of gas.
Feb 16, 2022 at 2:28 AM
It sounds like either you have a large vacuum leak, or the fuel pressure is too high. Have you ever noticed any black or gray smoke from the exhaust?
Do me a favor. I need you to check for diagnostic trouble codes. The truck has an OBD1 system and doesn't require a scanner to retrieve codes. All you will need is a short jumper wire or even a paper clip. Here is a link showing how it's done:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Try that and let me know what you find. Also, please confirm the engine size. There are several different V8 engines that were offered.
Take care and I'll watch for your reply.
Feb 16, 2022 at 5:33 PM
RONBELIFORE@YAHOO
  • 4 POSTS
The engine size is 5.7L. I believe it is black smoke.
Feb 17, 2022 at 2:27 AM
RONBELIFORE@YAHOO
  • 4 POSTS
I did not try the code yet, will do today.
Feb 17, 2022 at 2:28 AM
Let me know if you get codes. The black smoke is an indication of too much fuel. It could be the fuel pressure regulator, a faulty coolant temperature sensor, or even bad injectors. Let me know if there are codes.
Feb 17, 2022 at 2:32 PM
